Search K
Appearance
Appearance
By default DirectAdmin is listening only on port 2222, so, the access URL would be:
or
Several people are unable to connect to DirectAdmin on port 2222 due to firewalls or proxies. It is possible to setup Apache to allow DirectAdmin to run through Apache using its proxy options.
In this example, we'll setup DirectAdmin to run through with server IP . Type your server's .
With the custom template system, we can add sufficient overrides to not need to make any changes to the templates themselves.
|*if SSL_TEMPLATE="1"|
|?HAVE_PHP1_FCGI=0|
|?HAVE_PHP2_FCGI=0|
|?HAVE_PHP1_FPM=0|
|?HAVE_PHP2_FPM=0|
|?CLI=0|
|?HAVE_PHP1_CLI=0|
|?HAVE_PHP2_CLI=0|
|?SUPHP=0|
|?HAVE_PHP1_SUPHP=0|
|?HAVE_PHP2_SUPHP=0|
ProxyRequests off
SSLProxyEngine on
ProxyPass /phpmyadmin !
ProxyPass /phpMyAdmin !
ProxyPass /webmail !
ProxyPass /roundcube !
ProxyPass / "https://server.example.com:2222/"
ProxyPassReverse / "https://server.example.com:2222/"
#ProxyPreserveHost On
|*else|
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteCond %{REQUEST_URI} !^/.well-known
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI} [R=301,L]
|*endif|da config-set x_forwarded_from_ip "12.34.56.78"NOTE: The above assumes that you've setup SSL for your Hostname with this guide , so that the actual :2222 access matches, in the Proxy settings above. Because cp.example.com is a User Level domain, it cannot be your server.example.com , so they'll probably be different.
LiteSpeed is slightly different in terms of using the ProxyPass option. For new method A, step 2, use the following instead:
|?HAVE_PHP1_FCGI=0|
|?HAVE_PHP2_FCGI=0|
|?HAVE_PHP1_FPM=0|
|?HAVE_PHP2_FPM=0|
|?CLI=0|
|?HAVE_PHP1_CLI=0|
|?HAVE_PHP2_CLI=0|
|?SUPHP=0|
|?HAVE_PHP1_SUPHP=0|
|?HAVE_PHP2_SUPHP=0|
RewriteEngine On
#RewriteCond %{REQUEST_URI} !^/?(phpmyadmin|phpMyAdmin|webmail|roundcube|)/
RewriteRule ^(.*)$ https://cp.|DOMAIN|:2222/$1 [P,L]
|*else|
RewriteEngine On
|*endif|Note, LiteSpeed dose not allow proxying to just any value. You if you get this in the error.log:
[REWRITE] Proxy target is not defined on external application list, please add a 'web server' with name "https://cp.example.com:2222"then you'll need to add an approved proxy web server in your LSWS panel Admin > Configuration -> Server -> External App -> Add for each host that will connect to DA. Should we find some way to override the "Host" value sent to LSWS from the redirect, then the value in the template could be unified, saving the need to load up everyone's cp.|DOMAIN| in the LSWS admin area. You'll also need to hit the "graceful reload" option after changing things.
Edit the /etc/nginx/nginx-includes.conf file and add:
server {
listen "12.34.56.78:80";
server_name "cp.example.com";
include /etc/nginx/webapps.conf;
location / {
proxy_pass "http://server.example.com:2222/";
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_redirect "http://cp.example.com:2222/" "http://cp.example.com/";
}Restart nginx:
systemctl restart nginxIf you're still unable to login run DA in debug mode, level 2000.
Checking referer "https://server.example.com/" to "server.example.com:2222"
Referer port (443) does not match DA's (2222): "https://server.example.com/"In which case, you'd need to disable the port during the referer checks: https://www.directadmin.com/features.php?id=2194
By default, the dataskq will make sure that the "directadmin" process is running. You can take it a step further if you'd like to confirm that DA is responding and a user/pass is working correctly.
First, create a login key for a sample DirectAdmin account. Set: Key Name: curltest Key Value: Random Expires On: Never Uses: 0 Commands: Allow: CMD_API_LOGIN_TEST Allowed IPs: 127.0.0.1 and enter your current password to create the key. The long string on the next page will be the password you'll use below.
Type in your:
Username:
Login Key:
Edit the script /home/username/da_test.sh and paste in the code:
#!/bin/sh
#DEBUG=0 normal running after settings confirmed
#DEBUG=1 basic output during testing to confirm settings
#DEBUG=2 raw output to see what's going on
DEBUG=0
USER="username"
PASSWORD="loginkey"
CONFIG=curl_config.txt
echo -n '' > ${CONFIG}
echo "user = \"${USER}:${PASSWORD}\"" >> ${CONFIG}
RUN="curl --config ${CONFIG} --silent --show-error http://127.0.0.1:2222/CMD_API_LOGIN_TEST"
if [ "${DEBUG}" -ge 2 ]; then
eval $RUN
else
#stderr to cron output
RESULT=`eval $RUN 2>&1`
RET=$?
COUNT=`echo "$RESULT" | grep -c 'error=0'`
if [ "${COUNT}" -gt 0 ]; then
if [ "${DEBUG}" -ge 1 ]; then
echo "all is well";
fi
exit 0;
else
if [ "${RET}" -eq 0 ]; then
echo "Unable to verify login. Try DEBUG=2";
echo "curl returned code 0, so is likely a user/pass issue";
exit 1;
else
echo "$RESULT";
echo "curl returned code ${RET}";
exit ${RET}
fi
fi
fiMake it executable:
chmod 700 "/home/username/da_test.sh"NOTE: If you're running DA with https, change http to https in the RUN variable. Same applies if you're not using port 2222, adjust the port there.
"/home/username/da_test.sh"; echo $?If you see '0' as the output, that's a good thing. Set DEBUG to 1 or 2 to help sort out any issues.
"/home/username/da_test.sh"and do not press the "Prevent E-Mail", or else you won't get any notices.
